All you guys running 315's out back....
i had the Sumitomo 315/35R17's on my 17x10.5 bullitts and when i took the wheels off last week i noticed some rubber built up on the tailpipe on the right side... i assume its from the rear shifting in corners as it had a fair amount of clearance...
im running Nittos all around now... 245/45R17 555 in front and 315/35R17 555R in back
I just ordered a set of 315 35 17 Goodyear GSD3 tires for my new 10.5" wheels. Is it wrong to go with a cheaper set of 255 40 17s up front? If I go with a set of BFG sports I will save 180 bucks. Is there anything wrong with this? They are both z rated tires.
I'm running the sumitomo 315 35 zr 17 htr35z on the rear of my d.d bullitts,and stock good years up front on my stcok bullitts.It's really not a big deal.:nice:
are you guys saying there isn't clearance for your tailpipes by running wide tires??
I make houses shake at idle!
Do you have an aftermarket catback?
I had this issue with my 275s rubbing my Bassani catback. The guys who installed my 315s also do custom exhaust work so they dimpled my pipes and bent them a little to get them out of the way.
Also, you may have to get your rear fenders rolled (mine are). On tight turns there is a possibility the tire will rub the fender.
GSD3's are the widest made 315s out there.
