So hers the problem lets see if anyone knows he answer. When im driving about 50% of the time ill push on the gas and suddenly the power starts to die and I can feel the car surge back and forth but when you push the gas to the floor it will jump out of it and go
. Most often it happens in 2nd gear at about 2500 rpm but it also happens in other gears to. I recently did the AODE to T5 swap and swapt computers as well and I removed my smog pump. But before I did the work there was no problem so im wondering if it’s a sensor going bad or vacuum or something I have not thought of? So PLEAS help if you can thanks
