Alternator/Gauge reading question
89-5leet-eh
Have a question regarding the charging system on an 89 LX 5.0L.
At 1500-2000 rpm( with accessories running) my gauge reads 12-14 volts approx- mostly at 12 but at idle and with accessories running such as windshield wipers,heater, headlights the gauge drops down to 8-10 .I also noticed the wipers slowing down at idle.I recently replaced my alternator that was making a slight buzzing/humming sound( and killing the old battery) with an alternator off a 88 2.3L(slightly used).I was told at the parts store the alternators are the same on the 5.0L and 2.3L so i figured id be able to use it.I installed a new Interstate battery appropriate for the car and have no corrosion on any wires.So...is it normal for the guage reading to drop to 8-10 V at idle or should the alternator keep it near 12-14V.A new alternator is close to $300.00.At this point im assuming that ill need one.What should the guage be reading with a properly functioning system thru the rpm ranges?Thanks alot for any feedback.
The alternator should read 13.2-14 volts at idle with no accessory load. At 1500 RPM, you should see 14 volts with normal accessory load (lights, wipers, low blower).
Have the alternator checked out in the car. Most auto parts stores will do it for free.
If your alternator is defective, consider replacing it with a 130 amp 3G alternator from a 94-95 Mustang. See Stangnet 3G install sticky 3G Alternator Install: A How To - Mustang Forums at StangNet. You can buy a used 3G alternator from the junkyard for $25- $50 and have the parts store test it before you install it on the car.
Also be sure you're using an accurate voltmeter (the stock gauge is not accurate for diagnostics, nor does it take into account chassis-wiring voltage-drop).
If you drop much below 11 V, the battery light should come on and the car can start to run funny.
Take Jrichker's advice on the 3G and enjoy.
Good luck.
alternator
Thanks for responses and info,i will certainly check into 94-95 alt.
I wondered if pulley sizes were diff from the alt on the 2.3 and the 5.0 so dbl checked .The 5.0L pulley is smaller by about a half inch approx in diameter so maybe its as simple as that.Will try n swap them around first and see if it keeps the voltage up.I didnt think of it before making this post but i took my 93 LX out for a drive and watched the voltage guage ( amazing how i never paid it much attention before :rolleyes:) With everything running full tilt high beam on, wipers at full ,heater blowing full, rear defog and stereo going the needle fluctuated slightly from 14 on the dash guage and never dropped, either at idle or thru to highway speed.Thanks again for the advice, this forum has helped me out many times and i appreciate the time you all take to reply to questions.
