AMW PCV catch can/separator
blackcloud50 said:
Although pretty expensive, anyone have any thoughts or experience with the AMW separator? The only thing I see not the best other than the cost is that you have to unscrew the top to see how much oil is trapped.
http://www.accmachtech.com/pcvcatchcans.htm
This is a familiar subject.
Ideally the inlet line would be tangential to the outer edge of the can. This forces the oil to make contact with can and helps settle the oil out of the incoming air.
For a sight line you just need to tap a hole in the top and bottom of the canister, install a couple of elbow fittings, and a hose between the 2 fittings. The oil level in the canister will always be the same as the level in the tube.
I would like to see the guts of this thing.
For the price I would stick with the Home Depot separators. I picked up one of the larger ones that they stock and it looks pretty decent.
Thanks for posting this, I have not seen these canisters.
jason
