well my 6 month old motor is dead..
.. I have a good size chunk removed from my piston. not to mention a pushrod in the shape of a C.. and a broken valve spring...and broken valve.
Looks as if the valve spring broke and MR. Piston and Mr. Valve had an introduction in the middle.. both lost.. So i parked the 66..
contemplating building a new motor off of this block since a piston is trashed..and there is some damage to the cylinder wall.
Parking it for a while till I have enough money to build it right
Im thinking of either two options
A.
347 stroker
eagle rods
scat crank
srp 9:1 forged pistons
Afr 205 heads
anderson B-41 cam
Edelbrock Performer Rpm Pro Flo EFI
and either a Vortech T trim Or a Turbo
B.
427 stroker
what do you guys think..
.. I have a good size chunk removed from my piston. not to mention a pushrod in the shape of a C.. and a broken valve spring...and broken valve.Looks as if the valve spring broke and MR. Piston and Mr. Valve had an introduction in the middle.. both lost.. So i parked the 66..
A.
347 stroker
eagle rods
scat crank
Afr 205 heads
anderson B-41 cam
B.
427 stroker
