another throttle body question
U2SLO450
118
Im getting ready to do my H/C/I swap on my 90 gt. I have the cobra upper and lower, e-cam and gt40p heads with 1.94/1.54 valves and .550" springs, Now the question is what size throttle body do i need, i hear half the people say 65mm and half say to get the 70. The car is a daily driver and will not see any more mods. Any suggestions?
If it is indeed 'no more mods' a good brand like Accufab, Holley, Eddy 65mm will flow plenty. Some think 'bigger is better' in this case, but they will flow all you need, either 65, 70, 75.
YEAH RIGHT!!!:lol: :lol:
The only other thing i have planned is maybe having the cylinders and bearings freshened up some. That brings up another question, Should i have the cylinders and bottom end done as well at the same time? I had planned on just throwing on the H/C/I and going. It seems like its pretty strong right now and plus i dont want to have to pull the motor. So do you think it will be fine with a stock bottom end?
170,000 and running strong, theres no noise or smoke, it holds good oil pressure and it doesn't burn any oil so i hope it will be alright. It wont be seeing much abuse at the track so it should be fine right?
