Any chance 65 clutch/brake pedals will work in a 67?
351stang67
I have come across a complete toploader 4 speed transmission setup out of 65 fastback, complete with EVERYTHING except a clutch, including clutch pedals, linkage, driveshaft yoke and a hurst shifter. I have a 67 coupe with a 351C and C6 automatic that I want to convert to a manual setup.
Will the pedals work in my 67? Or is there any "chance" of them working?
It is such a good deal for the setup, but if I have to turn around and buy pedals and/or linkage because it will not work in my 67, then the deal is not so attractive. If it will work, I will jump on the deal.
What all will work in my 67 from the 65 in regards to this setup?
The whole setup can be had for $600, a good deal ?
You buy the package and sell the 65/6 parts to buy 67 parts. If its really a toploader and needs no work, sounds like an ok deal. I am not an expert on the 67/8 cars, but the shifter should work and you have to have the drive shaft check to make sure the length is good. I since you'll have an extra drive shaft, you will still have all the parts to go back to automatic. my .02 cents. good luck.
