well were to start..
I was having problem w/ car lacking power and when my car got up to running temp. it would not start or run right, well i startes diagnostic and ended up changing out a fare amount of parts. Now it will turn over and start up and then just die (rev up to around 800-1000 rpm and cut off). I have hooked up a code scanner but i get no codes (koeo, or C)
New fuel filter Checked pressure @ rail 40 psi w/ vac conn.
New (TFi) ignition module
New Distributor cap and rotor
new plugs gapped @ .052
New Plug wires
New Coil
New Air idle Control
New PVC valve
Checked and replaced worn Vac. lines
Tested ECT sensor Ohm'ed good and pwr @ 4.7 v
MAF has correct Voltage, and the sensor ohm'ed good, (have not yet back probed engine isnt running)
IAT sensor Ohm'ed good along with correct voltage
EGR voltage is correct (DPFE Sensor), and working. holds vac.
AIR pump works
I have not Checked the Charcoil cannister!!
PIP Sensor?? going to backprobe to ignition module but getting spark
Any ideas, input would be helpful, and thankful. Open to any ideas. please help!
Is there anyother ways to check stuff, (e.g., PIP sensor(halls), MAF)
Thanks, Joshua
New Plug wires
New Coil
New PVC valve
AIR pump works
Thanks, Joshua
