any one using procomp alum heads?
I have a set of gtp heads i'm porting for my bolt on 87 notch...i picked up a set of trickflow valve springs an a crane 20/20 cam...Now I'm thinking of going alum heads an the ones on ebay look pretty tempting...Any one running them and how are they? good power, good quality, good fit? any info appreciated!
ive got a buddy that has them....and he had some problems with the guideplates being off and whatnot.. the castings are great though for the price but the hardware (valves, springs, retainers) are junk imho. im tempted to just buy the bare castings and put good hardware in them
I got the heads on my 347. Here is what I have found.
1. If you are going to buy the heads, get them assembled from a reputable supplier. The pushrod holes going through the head are too small and need to be machined, a reputable suplier will take care of this.
2. Make sure you get guide plates from the same suplier. The guideplates needed are unique. You will not be able to get the roller rockers lined up correctly over the valves with any off the shelf guide plates.
3. They have large volume intake runners and are not really suited for a 302. They work better with a larger displacement engine to accomodte for the lack of torque from the large intake runners.
4. I will be replacing them soon, too much BS for the savings in money.
5. Beware that a lot of companies are selling these as their private label heads.
6. 5.0 Magazine used them recently on tehir 347 build up with mild porting done and made pretty good power.
7. The intake ports are slightly higher than stock so you will have to trim the tabs off of intake the gaskets to make them work
__________________
