I'm going to be rebuilding the 289 in my Mustang since it's blowing a lot of oil through the 7th cylinder. I would like to bump the power to around 300 hp if possible too. What heads/cam combos have some of you had luck with? Also, what intake and carb? I have about $1500-2000 to spend on parts and will have about the same to do the rebuild. Also, my current setup is a 100% stock D-code 289.
Thanks,
Matthew
Thanks,
Matthew
