Any Tips Or Help On Cd Player Install
  • Thread starter Thread starter Steve69
  • Start date Start date Dec 16, 2005
Steve69
233
  • Dec 16, 2005
Hi Guys
Im installing a CD player in a 69 Mustang. I know that I have to cut the
plastic cover on the front to make it fit. What I was wondering was the
metal bracket that holds the old radio in place and the heater controls.
I emailed a fellow Mustanger and he said he welded the cd sleave to the metal bracket. Any other tips or anything else that would also work good. I wanted as much info as I could ge before I start cutting things up.
Thanks
Happy Holiday.
Steve69
68rustang
1,537
Cleveland, OH
Dec 16, 2005
  • Dec 16, 2005
Not really sure what you are asking.
Steve69
233
  • Dec 16, 2005
How do you mount the Cd player so it stays in place?
Thanks
yeloxr7
429
  • Dec 16, 2005
You could always buy the $350 billet piece:
http://www.jmeenterprises.com/69_radio_bezel.shtml
Otherwise you will have to cut up the factory plastic piece to fit the cage for your new radio. Attach the cage to the radio face. Install the radio face and cage into the dash. Add a bracket made from perforated strap to support the back of the cage. Slide the unit into the cage.
I installed an older cassette unit in my car this way. I left the front metal brace off. Since it was a "conventional" radio with a rectangular center part and two knobs, I just trimmed the opening to fit my radio. Your work on the radio faceplate will be a little more extensive.
Max Power
1,774
St Paul
Dec 16, 2005
  • Dec 16, 2005
There is a cheaper ($99) bracket and bezel available from the Mustang houses. No need to fab anymore.
Steve69
233
  • Dec 16, 2005
I had bought that $99.00 piece from NPD thinking that but what I received
was a cheap plastic cover that looked like it would dress up the front nice.
I called NPD and they told me this would hold the cd player no problem. To
me it looked liked one good bump and the cd player was going to be on the floor. I sent it back.
iskwezm
4,159
20
79
Rowland Heights,California
Dec 16, 2005
  • Dec 16, 2005
Ive always just used the sleeve and never had a problem.I dont recall what your dealing with but it cant be that hard to mount.
68rustang
1,537
Cleveland, OH
Dec 16, 2005
  • Dec 16, 2005
It doesn't take much to hold a headunit. Cut a hole that will fit the sleeve, insert sleeve, bend tabs out to lock the sleeve into the cut out, mount the rear using a metal strap to the mounting stud.
G
Help! Radio, door chime fuse keeps blowing.
  • goofyfoot53
  • Sep 9, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 9, 2025
91AOD5.0LX
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
TB Injection Install (Aces Killshot)
  • LILCBRA
  • Feb 5, 2024
  • 4 5 6
23K
1974 - 1978 Mustang II Talk & Tech Dec 1, 2024
LILCBRA
