Anyone ever use 05+ injectors on a 94/95?
redsn95gt
143
Need a set of 30#ers for my setup. Got a friend with some ford oem 30# injectors off a 2007. Can i use the uscar to jetronic adapter and use these on a 94/95? Issues, problems or bad idea?
Thanks
Hmm, I'm curious as to how that's gonna work. Let me know when you do it. Are you sure they won't just bolt up? Have you seen them? Why not just get a set of 30's that are a direct install?
The format for the wire harness has changed with newer cars, I would assume it would work but I thought I would ask if anyone knows for sure. I can get these dirt cheap and sell my 24s for same price and break even
:shrug:I have no idea if they will work or not but I'm certain that they must have the same impedance to work. Ford used a high impedance injector (~14 ohm) or did for our cars. If that has changed for current models they won't work and I seem to recall reading that using low impedance (~1-3 ohm) injectors may damage the ECU as they would require a different driver.:shrug:
