Anyone have Predator for 02+ gt
i've seen the predator for the cobras. my friend is a diablosport distributor and sold one the other day to some guy. i didn't get a chance to check it out and see em usin it. just saw the product itself. looked cool, i think the case was some light green see through color. i just wanna see what it can actually do.
Ordered Mine from rpmoutlet.com
I just ordered the diablo predator flash tuner for my 2001 GT from rpmoutlet.com. The cost was $399. They advertise an availability date of March 16th. I plan to use this handheld tuner to calibrate my speedometer for 4.10 gears, improve my automatic transmission, advance my timing, and adjust the fuel curves. All these things can be done with a Diablo computer chip but the predator allows you to make these changes without re-burning the chip for each new modification.
You can order it, but it doesn't they'll be sending it anytime soon :bang:
Ruckus46Gt said:
I called summit the other day and they said they had them in stock for 2000 gt's
i'd ask them for a pic of it with today's newspaper before buying from them
there are like 50 threads where people have asked about the Predator, all ending with "it'll be out in a few months"
It's neat that you can bump timing and fuel curves but.....
You can only bump the timing globally, meaning if you add 3 degrees, it adds it all across the rpm range. I think it's the same with the a/f, so if you are only going lean up top, then you have a problem. The Predator wont let you lean up down low, then richen the mixture as the rpms climb. Only a tuner can do that for you, then burn it to the Predator.
I do like the other things it does, like the fact that you can download other tunes for it off the internet and aren't required to get a dyno tune everytime you change something. It's like a Hypertech on steroids.
