Anyone using a taurus 3g alternator?
  • Thread starter Thread starter wazazzle
  • Start date Start date Feb 12, 2006
W
wazazzle
618
In the dumpster behind McDonalds. WA
Feb 12, 2006
  • Feb 12, 2006
Like it says, I picked one up. But before I install was wondering if you ran into any problems or slight mods needed. I don't want to get halfway through my install only to find out I can't use it. It's my d.d. so I must get it done during one install day. I've read a few people say it might need a spacer for the pulley, but they never indicated what size. Then I read many people debate about being able to use UD pulleys, is this true? Any help on this topic would be great. It's pretty hard to come by a cheap sn95 alt in my town, so my 3g came from a taurus. Thanks
sgarlic
3,085
Feb 12, 2006
  • Feb 12, 2006
You'll just have to see if the holes line up, and if so, maybe also reclock the terminal on the back. I say, feh, to underdrive pullies.
HISSIN50
34
129
Feb 12, 2006
  • Feb 12, 2006
I would read Monte Smith's article and Mustang Central's article. Jrichker has a very comprehensive post about performing the upgrade, including what wiring supplies you might wish to purchase.
The actual swap takes about 30mins-1 hour, mainly depending upon how you clearance the bracket. Time taken, of course, can vary. It will not take long though.
Good luck.
W
wazazzle
618
Feb 12, 2006
  • Feb 12, 2006
Good luck.
I've search high & low on articles about the taurus 3g. I could only find 2 or 3 articles about the taurus 3g & 6g, but both say they had difficulty with spacing the pulley. I know it fits into the bracket and even saw a pic from cardomain of someone with a 6g installed (tried contacting him from but no luck). It's just the issue of spacing the pulley so the belt doesn't fly off. Anyone?
bbf545
  • Feb 12, 2006
Best I can do is give you some links if you don't have them.
http://www.fullsizebronco.com/forum/showthread.php?t=26658
http://fullsizebronco.com/forum/showthread.php?t=25824
http://fordfuelinjection.com/index.php?p=63
Please be aware that some of the links above have huge pics so if your dial up beware.
Later on!
Les
8950HO
658
  • Feb 12, 2006
1996 and up 3g alternators are a little different than 94-95 3g`s.
They have a different case and different pulley spacing,(none of the 3g sites tell you this).
ASP told me their 1-7/8" OD alternator pulley will not fit a 96` up 3g.I asked about using a 5/8" washer as a spacer,but they said it would push the pulley grooves too far out causing the belt to walk off.They can custom make one for $80.
Maybe someone here has tried using a spacer/washer on a smaller 2g pulley or OD pulley on a 96`and up 3g and can tell you how it worked.(if it worked).I`m just going by what ASP told me.
The 3g alternators come with huge 2-1/2" diameter pulleys that are too big for underdrive pulley use on a 5.0L stang,so your probably going to want a smaller one.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
  • dan50
  • Jul 18, 2026
dan50
Electrical No charge from 3g alternator
  • BigShowJoe
  • Nov 9, 2024
Fox 5.0 Mustang Tech Nov 18, 2024
Mustang5L5
