AOD question.....
UnderdogGN
74
hey guys...is there a way to shift the AOD into overdrive at WOT??? i was just wondering because i need another gear at the end of the track or something because im screaming through the traps in third and dont want to change the rear gears again...any simple solutions?????
thanks
WOT in OD is a big :nono: in a stock AOD. I would only consider it if you had a larger OD servo and the wider OD band. With a stock servo and the stock OD band it won't last long.
Best solution is a set of taller tires for the track.
