  • 1994 - 1995 Specific Tech
AODE rebuild questions
  • Thread starter Thread starter StinkinLincoln
  • Start date Start date Jun 18, 2007
StinkinLincoln
240
Louisiana
Jun 18, 2007
  • Jun 18, 2007
i have a 95 GT with the AODE.
it has a 331 that will push around 375 to the ground(around 425 crank hp (guess). i may put a on a 100 shot down the road.
my question is i need to rebuild it. i will be taking it to a local shop recommended by a master tech.
what do i need to tell them i want in the tranny to hold all this hp?
what will i need for the tranny?
:Valve body, clutch packs, od band, mechanical diode sprag, hardened input shaft, wide ratio gear set, deep alum. pan? i have a 14,400btu b&m cooler.
im just not sure what parts the tranny needs. prices would be great also THANKS!
also will the stock VB be fine and use the tweecer to tune the shift firmness? i want that baby to shift as fast as possible (less heat, faster, easier on tranny, and feels kool at the same time lol)
StinkinLincoln
240
Louisiana
Jun 18, 2007
  • Jun 18, 2007
also, would a transbrake kill my tranny quicker?
im debating to either foot stall and flash the converter
or use a transbrake
maby even line-loc
whats the downfalls of a t-brake?
Stanger007
2,015
Baton Rouge, LA
Jun 18, 2007
  • Jun 18, 2007
My vote is to start off with a beefier 4R70W since you'll have the twEECer. I got mine from Don LaSota's car and absolutely love it. I think they were putting down somewhere around 700rwhp through it and it took it.
Have it Jmodded or do it yourself. Don's site has some great info on this.
More info here: http://www.mustang-tech.org/wiki/94-95_Mustangs_Drivetrain_Automatic_Transmissions
Wes
StinkinLincoln
240
Louisiana
Jun 18, 2007
  • Jun 18, 2007
there isnt much difference between my AODE and the 4r70w besides the wide ratio gear set and the mechanical diode sprag. i can have the shop install those.
Stanger007
2,015
Baton Rouge, LA
Jun 18, 2007
  • Jun 18, 2007
Excellent article here: http://www.tccoa.com/articles/tranny/transmission/index.shtml
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Advice after break down.
  • bjornsn95
  • Jan 17, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
D
1989 rebuild tune?
  • Duramax6
  • May 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2024
Duramax6
D
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
