brianj5600
I think that they are both only as good as the tuner. I have seen cars at the drag strip leave from idle and pull the wheels off the ground, I don't think they are giving much up in throttle response.
jerry S said:I discussed my set up at length and in detail with Andy "the Butcher" Dunn and he opined that the roller cam I am currently considering would net me an additional 25 hp over what I have now.
mdjay said:Better understood!
Any response gain from a roller over a flat tappet would be miniscule, and wouldn't register on the seat of the pants meter. The difference comes not from the friction reduction (there is some, just not as much as you'd think, as others have said here), the gain comes from the faster ramp profile possible with a roller. You get more area under the curve when relating to the time the valve is opened off the seat. Using a smaller carb also results in EFI-like response, and also using an EFI cam grind with less overlap helps too. I'm running a factory Ford F4TE hyd roller in the 5.0 in my Ranger and it behaves damn near the same as any EFI although it's carbed.scouttrooper said:I believe there is at least one other benifit to having a roller setup, (reducing friction, increasing breathing), and that is an increase in responsiveness. I think in terms of how your car feels, that change can feel just as dramatic as an increase in HP. Hitting the pedal and having it push RIGHT NOW can be just as thrilling as extra HP's. In this case you may get some of both. Am I all wet or have any of you experienced this?
Hack said:EFI is more responsive than a carb, but a hydraulic roller is not more responsive than a flat tappet hydraulic.
The motor may have more power throughout the RPM range, but that is different than responsiveness. If you're going to define responsiveness as having more power, then anything that adds power adds responsiveness. You could also remove weight from the car and that would add responsiveness.Route666 said:Don't roller cams allow faster ramps? Are the gains from having faster opening and closing and the same overlap and duration not worth it? They should allow better breathing but maintain more low-speed response than a similar-flowing flat-tappet cam with more duration / overlap right?
EDIT: - I just noticed D.Hearne just explained all this in the previous post.
Hack said:The motor may have more power throughout the RPM range, but that is different than responsiveness. If you're going to define responsiveness as having more power, then anything that adds power adds responsiveness. You could also remove weight from the car and that would add responsiveness.
I always thought responsiveness meant the amount of time between a throttle input and an engine response and/or how fast the engine will rev without any load. Totally different. For instance a tunnel ram set up would have less responsiveness than a low rise intake because it takes longer for the increased fuel/air mix to get to the cylinders after stepping on the loud pedal. Or people use a light weight flywheel or remove mass from the rotating assembly to increase engine responsiveness.
edit: for example, I once had a Quadrajunk carb in a Generic Motors product that had really bad bog. If I floored it from an idle, the engine would bog for a second or maybe more - then it would finally take off. That's bad responsiveness.
Ok, gotcha now.Route666 said:I didn't define responsiveness as more power, in fact I thought of it as you do. Have another look, I basically said what you did.
The advantage I see of the roller cam is the ability to maintain responsiveness (by not having too much duration and overlap) while allowing better breathing through the valves spending more time at full open than a flat-tappet cam with same duration and overlap. These things - power and response are usually mutually exclusive, because more breathing used to mean more duration and overlap which kills low-speed intake and exhaust velocity - leading to less air-fuel in the cylinder at low speed. Faster opening and closing gives more of BOTH.
What I'm wondering is if the benefits of the roller ramps is in the 2% or 20% range of "better" than flat-tappet.
Hack said:I personally really like rollers for a couple non-performance reasons.
1. Not just Rotella, but pretty much all the oils for diesel trucks. 4-stroke bike riders like me would rather get a gallon of it for the same price as a quart of bike oil. It has more zinc and less molybdenum. However, engine oils are vastly better than they were in the flat cam era so I wouldn't be concerned with one wearing out faster. Think about how many OHC engines these days run cam-over-bucket lifters or slider-type rockers.Hack said:1. Modern oils don't have the additives that flat tappets really like for the best lubrication (although you can get Shell Rotella T as an alternative).
3. The roller is the current hot set up, and it's easier to find a deal on one if you go to a roller block. The late 80's roller motors are really easy to find now-a-days for builds.
BlueMonster65 said:an engine is considered near zero friction anyway because of the oil.
