  • 1994 - 1995 Specific Tech
As HP increases...
  • Thread starter Thread starter toyman
  • Start date Start date Aug 31, 2008
toyman
1,944
54
79
Vernon BC
Aug 31, 2008
  • Aug 31, 2008
I've noticed that as power increases so does the squirrliness, if that's a word, of the rear end on WOT shifts. Is there something that needs to be improved to reduce the amount of fish tailing that occurs. I have replaced the rear upper control arms and I do have a M5400-A suspension system. Haven't done a full throttle shift on my recent rebuild until today and although I felt that I had good control it was none the less a little un-nerving. Stickier tires??
Stanger007
2,015
Baton Rouge, LA
Sep 1, 2008
  • Sep 1, 2008
Some "real" tires are a must. I started using Nittos as a daily driver tire back when I had boltons and haven't looked back since. If you don't drive a lot and it's a good weather car, the Mickey Thompsons are even better.
Wes
V
viridionplague
98
  • Sep 1, 2008
good sticky tires will help alot with that, also looking into a torque arm and panhard bar combo would be a good idea as it cleans up alot of the sloppy mess that ford made with there 4 link design.
the torque arm and panhard bar might not help directly with wheel spin but will help out with the way the rear end of the car behaves, making it feel alot more stable and controllable when the wheels are spinning, and will also improve just about all aspects of driving the car such as launching and cornering.
Zero Signal
2,633
Tucson, AZ
Sep 1, 2008
  • Sep 1, 2008
I think it may still get squirly with the torqe arm + panhard bar but it would probably be much easier to control. I've seen lots of Camaros and Trans-Ams getting very squirly on the track and I'm FAIRLY certain those cars have the torque arm and panhard bar from the factory.
Venom351R
4,548
41
98
MAINE
Sep 1, 2008
  • Sep 1, 2008
315 Nitto's
Great street tire when more traction is a must.
Height of wheel well opening over the tires, front and rear, and adding clearance for 17x9 wheels up front
  • Blue Thunder
  • May 21, 2024
1974 - 1978 Mustang II Talk & Tech May 21, 2024
LILCBRA
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
After a decade, I am no longer Stangless!
  • Jsmiley
  • May 27, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2024
manicmechanic007
L
Torsen T2R (M-4204-T31H), excessive play?
  • letumeternum
  • Aug 24, 2023
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 24, 2023
letumeternum
L
Autocrossing my 95 GT convertible
  • Bill95
  • Dec 6, 2021
5K
1994 - 1995 Specific Tech Dec 25, 2021
7991LXnSHO
