  • 1994 - 1995 Specific Tech
Aspect Ratio for Front
  • Thread starter Thread starter SeventyMach1
  • Start date Start date Jan 3, 2006
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jan 3, 2006
  • Jan 3, 2006
I'll be bumping up to a 265 for the front, as I have a little rim showing. It makes me nervous. Let's just say if I curbed it, I would be pissed.
I run a 315/35/17 out back. What aspect ratio for a 265 tire would have the equivalent sidewall to a 315 tire? Would 265/40/17 match up perfect? 265/45/17? Or what?
Sidewall is nice ..... because of the comfort of the ride. But I'm tired of the look. The one's I've got have WAY too much sidewall. Plus, when I lower the car, it might not even clear good. So I want to widen the tire, but lower the aspect ratio. Any advice?
OrangeMustangGt
1,976
Cape Cod, MA
Jan 3, 2006
  • Jan 3, 2006
i would think that the sidewall hight you would want would be the same number as the rear, i mean with shouldent affect sidewall height. I am running 295/35/18s rear and 265/35/18s front, and the sidewalls are exactly the same height
Mustangless
903
home
Jan 3, 2006
  • Jan 3, 2006
http://www.miata.net/garage/tirecalc.html
This should help you. A 265/40/17 would have a 4.2in sidewall
A 265/45/17 would have a 4.7in sidewall
A 275/40/17 would have a 4.3in sidewall
315/35/17 has a 4.3in sidewall too.
After looking at this, I should have ordered 255/40s not 255/45s. I guess I will go up to the 275/40 next time
HISSIN50
34
129
Jan 3, 2006
  • Jan 3, 2006
the aspect ratio is the percentage of the width of the tire. So with 295/35's, the height is 35% of the width (0.35*295mm). And the fronts are 265mm * .35.
But the numbers can be off since dimensions from one tire manufacturer to another vary. And mounted heights can vary as well (wheel width etc as a factor).
I have found that crunching the numbers gets you close but you almost have to mount/mock up the tires on the rims to make sure it will have the right height and look.
Good luck.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Jan 3, 2006
  • Jan 3, 2006
Yeah, I knew that the aspect ratio was a percentage .... that's why I asked the question. Otherwise I would have just got the same. Maybe you lucked up Kyle ..... do you run the same brand tires front & back? Thanks guys.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Jan 3, 2006
  • Jan 3, 2006
Thanks for that link Mustangless. What do you run out back? I'm thinking I'll need the 265/40's up front, at 0.1" smaller than the rears. Or maybe the 265/45's at 0.4" taller than the rears. But I'm leaning with the 40's.
HISSIN50
34
129
Jan 3, 2006
  • Jan 3, 2006
From the choices you listed in the opening post, I knew you knew that Justin.
I was just trying to clarify and explain how Kyle might have ended up with the same absolute heights on his tires. Then again, it seems to me the difference in his sidewall heights is only around 10 mm, which aint much to the bare eye.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Jan 3, 2006
  • Jan 3, 2006
Looking back ay my post, I guess I did sound kind of rude. Sorry about that. Nah, I wasn't shooting that post at you JT. (or anyone really).
HISSIN50
34
129
Jan 3, 2006
  • Jan 3, 2006
OrangeMustangGt
1,976
Cape Cod, MA
Jan 3, 2006
#10
  • Jan 3, 2006
  • #10
yeah good point, im sure there is a diffrence, i just dont notice it
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
18” vs. 17” wheels on fox
  • dz01
  • Nov 14, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 28, 2024
2000xp8
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
