Average power gain from E-303?
  • Thread starter Thread starter FiveOCapri79
  • Start date Start date Aug 29, 2004
FiveOCapri79
164
Lawton, Oklahoma
Aug 29, 2004
  • Aug 29, 2004
Just got my new cam and was wondering if anyone knew how much power it picks up on a stock motor. Mods are in my sig and I'm still running the stock TB, bottom end, and heads.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 29, 2004
  • Aug 29, 2004
Sup, Woody, still sporting the capri I see? Anyways, back to your question..........I run an E-303 in my 89 SSP, w/ just a 190 lph pump, headers, TB, Mass air meter, and injectors it made 18.4 hp more at the wheels and the power range was changed greatly.
Dustin
FiveOCapri79
164
Lawton, Oklahoma
Aug 29, 2004
  • Aug 29, 2004
That's about what I was expecting. I'm hoping with the cam and new 4.10's(which will be installed shortly), I'll be able to run in the low 13's on motor alone. By the way, are you heading to FFW in Ennis next month? I'll probably just run in the True Street class again.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 30, 2004
  • Aug 30, 2004
I'll be there, we will be running the quick ford bracket stuff. We will be sporting the Mercury power, 1979 Zephyr 306, 14.3's on motor.......13.0's on a 100 shot.......11.70's on the 200 shot. see ya there.
FiveOCapri79
164
Lawton, Oklahoma
Aug 31, 2004
  • Aug 31, 2004
Alright, I'll see you there. Anyone else got any input about this cam?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 31, 2004
  • Aug 31, 2004
Yeah - but you won't like my input. The E303 is the same as Crane's PowerMax 2040 - Crane designed it for Ford Racing. Here's what they recommend with it:
GOOD MID-RANGE AND STRONG TOP-END POWER, REQUIRES MODIFIED MASS AIRFLOW, AFTERMARKET INTAKE, PERF. CYLINDER HEADS AND HEADERS, MUST USE 5-SPD AND 3.55 OR NUMERICALLY HIGHER REAR GEARS. REQUIRES CRANE SPRINGS AND RETAINERS. (50 STATE LEGAL 85-93, C.A.R.B. E.O. D-225-46) BASIC RPM 2400-6000
I think it's a terrible match for a stock-headed car. The stock heads are intake biased in flow, and would really like a split duration cam that helps the exhaust side. The 110LSA frequently gives folks fits with regard to idle quality; and while you may pick up a bit of peak HP, you'll lose significant bottom end torque. For a basically stock motor, there are MUCH better choices. If you insist on going forward anyway - be sure to upgrade your valve springs. The stockers are notorious for floating with the E, especially if they're tired.
I'd look at the CompCamsXE258 or XE264.
FiveOCapri79
164
Lawton, Oklahoma
Aug 31, 2004
  • Aug 31, 2004
I did forget to mention that I'm also changing out the valve springs and retainers with a set from Crane that handles up to a .550" lift. About the only thing thats done to heads are that they were slightly milled and I ported out the exhaust a bit. I pretty much have all of the mentioned upgrades and will be stepping up to 4.10's from my 3.73's.
R
Rob Parsons
  • Sep 8, 2004
I had problems with the E cam and the Crane valve spring kit for stock heads. I was getting a lot of noise when the motor warmed up. Ford Racing said they were too stiff for the E cam. I went with the Ford Racing spring set and had no more problems. If you look at the specs there is a big difference in the two
fawcett
380
Cohasset, Ma
Sep 9, 2004
  • Sep 9, 2004
sorry if i hurt anyone's feelings...
i have the e cam in my 95 gts and i hate it. i have run low 13's on street tires with it but the cam sucks on the street. the low end power on the thing seems pretty weak compared to other cams on the market which also offer better mid/high range.
but if the budget is tight then do what you can. i was told to switch my cam to a steeda #19 before my engine went in because it was designed for 94-95stangs which need more vacuum at idle. i thought that, that was a bunch of bs but i do regret it now... and presently i can not afford a cam swap so i am stuck with it
Fawcett
Black 1995 Gts
trick flow intake and gt40x's, 24lbs, fuel pump, mallory digital ignition, d&d viper spec 6-speed, alum d/s, cai, prom80, 65mm frpp tb, 3.73's, cobra r's brembos all around, and more....
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
