B cam with AOD
car already has a soft bottom end...add that cam to a stock head AOD car and you will be unhappy with the results. Cam swaps should come AFTER head upgrades...not before if you want to enjoy their potential.
b and aod would not be ideal IMO..higher rpm powerband combined with a soft bottom end of the AOD is sure to make you sluggish on the street. It's certainly your car and your opinion but the B cam is not a favorite grind of mine...certainly not in an AOD car.
A torque converter is on my wish list but theres other things I need to get first.
I already have 4.10 gears and just havent gotten around to playing with the timing.
I shift the car at 5500 when racing so Id need something that is good up to atleast that rpm.
Keep the stock cam and put on a GT-40 or Cobra intake with 1.7 RR's!! It will be good till that RPM and would give you more power then just a cam swap!:nice:
b303 with aod
I swapped out the stock cam for the b303. It runs fine, but the stock aod just sucks. The cam has good mid to upper power but the torque isn't that great and I have the 3.73s. I plan on the t-5 swap.
