B cam
  • Thread starter Thread starter StangzRUs
  • Start date Start date Jan 30, 2009
StangzRUs
23
Toronto, Canada
Jan 30, 2009
  • Jan 30, 2009
I have heard that the B cam takes special installation, it would be going into a 89 5 speed, is it true that is does need special install?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 30, 2009
  • Jan 30, 2009
Uh... what's "special installation?" It installs like any other hydraulic roller cam would.
88mouse
630
Mooresville nc
Jan 30, 2009
  • Jan 30, 2009
Don't waste your time puting a B cam in. If your going to run a ford cam go with the E.
9
90stang5speed
582
Columbus Ga
Jan 30, 2009
  • Jan 30, 2009
I agree with going with the E cam over the B. unless you already bought the B. My 90 had a B when I bought it and after it blew a head gasket I upgraded to the E cam, had the heads rebuilt, shaved .030, new springs for added peace of mind, & put on an Explorer intake with a 1" spacer between the top & bottom to top it off. There were no piston to valve clearance issues to worry about. Haven't been back to the track yet to prove how much I gained but it "feels" like it has more power than it did with the B
Bullitt347
I have been doing it wrong this whole time
4,061
3,133
204
Middle of Maine
Jan 30, 2009
  • Jan 30, 2009
Could it be that if "feels" like it has more power than the "B" cam because of all of the "other stuff" that was done and that it is not the cam at all that made the difference? The "E" cam actually has less duration than the "E" cam and in certain combo's would make less power, not more.
9
90stang5speed
582
Columbus Ga
Jan 31, 2009
  • Jan 31, 2009
Good point. I can't prove any power gains are from the cam alone.
Maryland Stang
1,656
30
39
Greenville, NC
Jan 31, 2009
  • Jan 31, 2009
No special installation is involved. Here's mine. I'm very satisfied.
DADDYJUSTANG
213
MANDEVILLE,LA
Jan 31, 2009
  • Jan 31, 2009
Bullitt347 said:
The "E" cam actually has less duration than the "B" cam and in certain combo's would make less power, not more.
Also , with the stock 1.6 ratio rockers on both cams the "E" has more lift, .498 versus the "B" with .480 . But if you put 1.7 ratio rockers on the "B" it bumps up to .510 lift for a cam that has more lift AND more duration. Now from what I have heard for the longest time .520 is the largest you can go with stock heads and pistons. So this won't work with an "E" because it would bring the lift up to .529 which would introduce the valves to the piston in a meeting you don't want to see. If you want just a little more on the "B" you can put on 1.72 ratio rockers and get .516 lift.
p.s. I can't remember if the piston to valve clearance is the reason for the .520 lift limit or was it the valve spring bind limit. Either way it wouldn't be good.
R
Rick James
172
burlington new jersey
Jan 31, 2009
  • Jan 31, 2009
I would be worried more about duration than gross lift as far as piston to valve clearance.Contact FTI or Camshaft innovations
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 31, 2009
#10
  • Jan 31, 2009
  • #10
duration has the biggest affect on PTV clearance, the pistons isnt even close to the valve at max lift, its closer to BDC. during periods of overlap with larger duration is where your going to run into problems.
white 89 GT
281
Tacoma
Jan 31, 2009
#11
  • Jan 31, 2009
  • #11
I thought the B cam was for the 85 carbed engine.
Im sure there is someone that would know more about it than me, its just what I heard.
bubba-dough
1,044
Indiana
Jan 31, 2009
#12
  • Jan 31, 2009
  • #12
scrap the idea of a Ford cam altogether....
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Feb 2, 2009
#13
  • Feb 2, 2009
  • #13
+1 on that.
I prefer the TFS Stage 1 camshaft myself
V
v8only
2,378
22
49
Feb 2, 2009
#14
  • Feb 2, 2009
  • #14
I went with a tfs 1 cam. couldn't be happier.
I have a feeling that by special installation, this means he hasn't ever tackled a project this big.
In a sense, yes it does require special installation.
I had to tear off all my front accessories and timing cover, then my rockers and intake to swap the cam. it's a big freaking project.
Anderson ford motorsports sells a tool that goes in your lifter holes that allows you to swap the cam by not pulling your lower intake. It holds the lifters up magnetically so they don't drop when you yank the cam.
This tool saved me so much time it wasn't even funny. It still is a big project though. I got lucky and was able to bolt it all back together and not change the oil pan gasket. However, there is a solid chance that you'll have to lift the engine up and change the pan gasket when you're done.
To the original poster....do NOT replace the cam unless you already have aftermarket heads and intake. It's not worth the trouble and will not really get you any gains with stock heads and intake.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 2, 2009
#15
  • Feb 2, 2009
  • #15
It is my opinion that the TFS1 camshaft is the best return for the $$$ spent, compared to a custom camshaft. It is about the only one "worth it" to me.
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
  • dan50
  • Jul 18, 2026
dan50
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
