wytstang
Mustang Master
I know we have a nice amount of stickies already but this should really be pinned when an iron rod up top.
You better believe itout of all the mag articles and countless threads I've read over the years YOUR info/data is the best and most accurate I've seen regarding this subject on our cars. Your data proved beyond a shadow of a doubt for me that G. Klass's (Accufab) article is absolutely right on the money on how to properly choose a TB ( again..CFM not the size of the hole).
you can if you have 2 different equations using the same variablesWith all due respect, you can't solve an equation with two variables.
Adam
Throwing your opinions around to bounce of others helps eveyone to make smart decisions about there own setups. what size opening does the Holley Systemax 2 Intake have?
when I hear or see someone post that they need a minimum of a 70-75-90 mm TB on a 7k or less 302.you can if you have 2 different equations using the same variables
I just found out the local guy actually saw similar results to mine once he pulled his graphs out He saw an improvement of ~10rwhp and 6ftlbs of TQ. He went from 325rwhp/353 to 335rwhp/359rwtq. I'll work on getting the graphs. Even in light of this, I'm dying to do the test again with a 94-95 75mm TB and comparing it to the 75mm fox. I'll post more details later.
Paul's friend did his tests on different days and different dynos. I feel that that somewhat disqualifies his data. Thats what makes Paul's test so cool, he actually went ahead and did something that always gets talked about but never actually gets done!
I'm still maintaining that:
Paul made more power because he went with a bigger throttle body. Based on what we see here, you can't say I'm wrong.
HOWEVER
If 5SpdGT (sorry I forget your real name,Dave?) said:
Paul made more power because he went with a Fox setup regardless of throttle body size. I couldn't prove him wrong either.
Air flow is not the deciding factor in producing horse power. Keep in mind that using a larger throttle body before the intake creates a larger pressure differential then a smaller throttle body, so that when the diameter inside the intake "necks down" greater velocity is produced, which results in an air charge of higher energy and a more even cylinder fill: more horsepower.
This is why (I believe) the Holley intake mentioned above necks down on purpose to create higher velocity before the air hits the cylinders.
A word on Volumetric Efficiency (VE): How VE is measured is critical to understanding this. VE is the Density of Air in the Intake Manifold / Density of Air in the Cylinder * 100 = VE%. Notice this has nothing to do with the flow rate of the throttle body before air enters the intake manifold. Having 100% VE would mean that the air density in the intake manifold is the same as the density in the cylinder. This is very difficult in a naturally aspirated engine! Especially in all 8 cylinders. Super and turbo charged engines have higher then 100 percent because they are actively pressurizing the air and stuffing it into the manifold before the cylinders can keep up with it. BOOST is a measurement of how much extra pressure is inside the intake manifold when this occurs. The more efficient the engine, the less BOOST is created by the power adder because the cylinders can get rid of that extra pressure faster. It can also be done naturally aspirated but it takes some tricky valve timing, exhaust scavenging, and you will be basically pulling no vacuum when your not in the RPM range over 100 percent VE so it wouldn't be street drive-able.
CFM is a critical measurement of engine components but its not the only one. Just something for you all to think about. And yes, I am a huge nerd.
Adam
Ok so based on 5spdgt chart, would a frpp 75mm be enough for my car?
