Backspacing for 15X10" wheels?....
'01 Steed
482
Michigan
What's the best backspacing, appearance wise, for 15X10's? I plan on running 26" ET Streets.
Also, what's the smallest wheel I can use up front with 13" Cobra brakes? I'd like to run 15x5's, with a 2-3/4" backspacing, but will that work?
Thanks!!!
The ideal backspace for a 99+ car is 7 inch for a 15x10. And not too sure about your fronts but there is a caliper clearance problem with 15 inch wheels and 13 inch brakes. A minimum of 3/4 inch spacer and minor clearancing of the brakes is required to fit a 15x3.5 weld wheel.
