Ok, I just got back frm the dyno earlier today and my hp is 255 annd torque was like 289? I have alot done to the car and I thought I should be putting out more!! I have an 347 Eagle short block, forged crank and pistions,Tfs heads 185cc, Holley systemax intake, trick flow stg 1 cam, 4.10 gears, T5 tranny, 32lb injectors, Saleen rear axle, MSD ignition and distributor, Griffin aluminuim radiator, Optima battery, A/C eliminator, 70mm throttle body, king cobra cluth, BBK longtube headers and x pipe, flow master exhaust 40series mufflers. We ran it about 5 times and they found out that my adj fuel pressure regulator was broken and open all the way to 80 lbs of fuel, would that affect it that much? Should I be putting out bigger numbers? I feel embarresed with those numbers after how much work Ive done to it!!!
