SuperchargedB87 said:DSS pro bullet 306.
Rick 91GT said:IMO try to find a good local machine shop to work with and have them assembly the bottom end if you can not do it.
Rick 91GT said:
After seeing some DSS motors I would let them build me a motor for my weedwacker. I am in the process of rebuilding a DSS motor for a customer of mine, tolerances and clearances were all over the place, really shotty machine work as well. IMO try to find a good local machine shop to work with and have them assembly the bottom end if you can not do it. If you need interals check out www.ADPerformance.com or [email protected] tell Brian I sent you
Check out "perkys stang or NoSlo90 or Cobra86" they all have very nasty 306 combos. Bill aka perky is deep 11's @ 120mph+
mstangfrk95 said:My friends combo in a 94 Cobra:
DSS Pro Bullitt 306 all options windage etc.
Curtis cam 630 lift 290 something duration blah blah
stage 3 AFR 165
1:6 rockers
Trick Flow race intake (ported)
30lb injectors
70mm TB
80mm mass air
Romac balancer
BBK longtubes
BBK shortie H-pipe
mac pro dumps
T56
4:30 gears
Laptop with TwEECer!!!!
its sweet!!
wont hook up in the the first 4 gears on street tires!!!!!!
Cobraman_1994 said:this is a local guys combo. its very impressive![]()
HiTech Motorsport 306, 10:1 compression, HiTech Custom Cam 224/222 .555/.528 111 LSA 113 ICL, AFR 165 heads,Edelbrock intake, 70mm TB,75mm MAF, 1 3/4 headers, 2.5" exhaust
340 RWHP
338 RWTQ
NoSlo90 said:My old 302 setup dynoed 369rwhp, 340rwtq. The current 306 dynoed 368.5rwhp, no torque reading was available. That # was just throwing the motor in and making 1 pull.
KickerStang said:What combo were you running. Those are impressive numbers from a 302.
