baddest 306 ...streetable combo you have ever seen
My setup is in sig. Very streetable. It also just passed emissions on the first try. I used a few tricks and it blew less than half the limits.
It made 365 rwhp @ 5800 and 353 rwtq @ 5200. Torque is above 300 at the wheels by 3000 rpm.
Baddest streetable 306 combo. I think it would have to be something like a R302 block and billet internals. Twin turbos. Nitrous fogger. Killer head-cam-intake combo. Aftermarket ECU with 3 programmed settings...street, race, race w/N2O..............dreaming. :banana:
Mine does alright, but I still think it needs to be faster. :)
5.8liter said:
Over the winter...I want to do a 306 buildup for a hatch that I just bought, and wanted to know a good combo and a few good suggestions. I want it EFI...streetable. I will add aluminum heads, and 373 gears possibly.
Here's my 94 GT:
302 punched to 306(Eagle 4340 steel crank&H-beam rods, SRP pistons)
Novi 2000
Edelbrock 1.90s
Cobra intake
AFM B-21 cam
1.7 rollers
42# injectors
70mm TB
80mm mass air
adj fuel pressure reg
unequal shorties, H-pipe, Ultra-Flos
3.73s
454.8rwhp, 428.8rwtq
mstangfrk95 said:
My friends combo in a 94 Cobra:
DSS Pro Bullitt 306 all options windage etc.
Curtis cam 630 lift 290 something duration blah blah
stage 3 AFR 165
1:6 rockers
Trick Flow race intake (ported)
30lb injectors
70mm TB
80mm mass air
Romac balancer
BBK longtubes
BBK shortie H-pipe
mac pro dumps
T56
4:30 gears
Laptop with TwEECer!!!!
its sweet!!
wont hook up in the the first 4 gears on street tires!!!!!!
What does that car run on a slick
My D1 Procharged 306 wasnt very streetable, but could have been made to be with a burned chip and dyno time. It never idled and if I ever did it again would avoid the FMU.
but with Twisted Wedge heads E303 cam Track Heat intake, 70MM tbody and of course the Procharger @ 9psi intake took me to over 120mph in the 1/4 mile.
Enough bashing on DSS, my old 306 was made by them and now the 408. I have never had any problems with the motors and the 306 worked flawless, until I put boost to it. As many times as the 306 saw high RPMS and then drove probably close to 40,000 miles. Before melting the pistons the motor was still as clean as could be and used no oil.
I havent started the 408 yet. Was supposed to get it in the new car last week, but problems with the heads meant I had to take them off and send them back to Kentucky to get worked on again.
Hopefully I can get them back and start it up in 2 weeks.
Heres a couple guys I know who run stock shortblocks and abuse them a lot, plus they are 100% streetable. The 1st one has his wife drive it quite a bit around town and such, its a nice old ladys car.
1. Stock Short Block, Trick Flow Twisted Wedge Heads, Holley Systemax Intake, Novi 2000, F-Cam, 42lb inj., Tremec TKO, Spec Stage 3 Clutch, Billet Flywheel, 1 3/4 Long Tubes, Off-Road H-Pipe, Dynomax Ultraflo's, 70 TB, 80 MAF, Wild Rides 6pt Cage, 5 Lug Conversion, 3.73's, Swanson Custom Chip
[email protected] on 17" Drag Radials
547 rwhp, 482 rwt
2. Stock short block, GT-40P Heads, F-cam, Vortech S-Trim W/2.95 Pulley, Stock Crank Pulley, Stock Rockers, Trick Flow Track Heat Intake, 42lb Inj, 80 MAF, 70 TB, Cartech Power Pipe, Tremec 3550, 3.55's, 1 5/8 Long Tubes, Pro Chamber H-pipe, Flowmasters w/dumps, Swanson Custom Chip
11.6@123
525 rwhp, 471 rwt
Hey Purestreet,
whats your combo? Just wondering, i love the pure street cars, especially the carbed ones. Was hoping with a set of AFR 165's and some 4.10's and good tires, to see mid to low 12's with the 85 in my sig, with room for improvement.
Really surprised to see only one other blower combo so far. My 300 mile per week commuter car is a very mild street and emmisions legal combo with a very old school 80,000 mile paxton SN92 and put out 390hp and 400 ftlbs of torque at 5 psi and gets 20+ mpg. It managed a 12.4 @ 114 on 28 x 9 ET drags with only 3.55 gears, too tall tires killed it.
Saw perky run last weekend, very awesome watching him launch in the other lane and pull the front tires 1.5' for 20'.
The big question is why have it be occasionally street driven? Drive it every day and enjoy it, you only live once so make every day count.
Jamie
Anyone with input on a CHP 306? This is the first negative anything i've heard about DSS....i've always heard that their clearances were above factory specs. Is it possible that this was a fluke or a rare occurance? I'm not doubting you at all, it's just surprising.
Marc2 said:
Hey Purestreet,
It's just a 308 cid with AFR 165 heads and custom grind cam from EDC@FTI carb'd air-gap intake(gasket matched) 650hp series carb from "quickfuel" 1 3/4 LT headers,x-pipe,dynomax"bullet" mufflers,4.56 gears 26x10 slick,no a/c or p/s and some other goodies :D
