Ok i got the Taylor battery relocate kit and switch for my 65 Mustang. I got the box installed and new wires run from box to engine compartment, i got the main power cable from
battery installed on solenoid on same side as previously done per instructions, Now instruction say to run a second cable from switch directly to the alternator to kill it when you turn
switch off. Here is my Question. I have a stock ford unit i believe its' 55 0r 60 amps, it has 3 different wires coming off it. The instuctions say to run the power for altnernator directly to the switch. What about the other wires on the alternator? Can anyone shield some light on exactly where the other wires on altnerator are suppose to go when you relocate the battery? Thanks....I'm not the brightest light in the box when it comes to wiring stuff.....
