I like what you're doing man. If you see any kind of sheet metal issues in the passenger side firewall behind strut tower investigate it thoroughly. My Vert pulled hard man. First I noticed the spot welds coming apart in the corner behind the passenger strut tower...then I noticed cracks behind the passenger fender...then in that corner under the cowl....my vert looked like an atlas map w/ 10 point cage and subframe connectors. The only way I might have been able to save it would've been to run support bars from the roll cage through the strut towers and into the frame rail behind the core support....and tied that with my strut tower brace.
The stress was all in the right corner. Mind you, I had a cage and a strut tower brace. Neither helped. Vert problems man.
That car is now crushed [emoji20]
