Belt Problems!!
stangz4life
155
tampa,fl
Ok my problem is that my smog pump froze..i planed on bypassing it i looked around and i have read that the belt needed is a 89.5 i bought it and seams to long, now i have tried so many diff ways of routing it ...please can someone give me a diagram or tell me the right way ...car is down.....hell i cant even remember the way the original goes now :bang:
here you go
Says to use an 84.5" belt when deleting the SMOG pump.. there is your problem
Keep a spare belt with you, I have had one come off and eat itself. There isn't enough tension around the power steering pump using this method and belt size, if you have underdrive pulleys.
Once the belt starts to get broken in, if you pop your hood and turn the steering wheel you can see the belt walking on the power steering pump pulley.
