Joe 5.0
Joes95GT said:I won't even get into the performance disadvantage of the tires....
From a street car perspective - their 555 series tire (not the 555R), is a horrible tire. They lasted about 20k on my buddy's 98 Talon. I have a comparable tire on my car, Michelin Pilot Sports, and I've got about 15k on the tires - they've still got 50% of their tread life left.
Joe
Ummm I have ~ 20k on my 555's up front with 2 open track events and a couple auto-x's and they look great. They are great in the rain, are not extremely loud, and look badass. They are not garbage tires, they are very decent for the money.
I have personally had both tires (and even the new bfg dr's), so I think I have a decent opinion on these 2 styles.
The Nittos are not garbage, they just arent as sticky. But, they also are quieter, ride better, perform in the rain better, have a stiffer sidewall, and are still being made. Think of the Nitto's as a sticky street tire, versus a drag radial. Now, I have pulled 1.9 60's on the Nitto's, and Paul has pulled 1.7's so they can be run succesfully at the track. They are just less consistent at the launch pad as far as whether they will stick or not.
Another plus is that they can be used pretty successfully at handling courses if you are into that kind of thing. I like to go to track rentals a couple times a year and really lean my car in the turns, versus boring driving in a straight line. I have literally been at the road course and hit a drag strip on the way home. They performed decently well at both, whereas the bfg's would be retarded at the raod course.
The Comp TA dr's are super soft, soft enough to stick your fingernail into even when they arent warmed up. They are decent at the strip because they have a soft sidewall, but that makes them loose feeling on the street. This also applies to the shorter sidewall sizes too, because my 225/45/17 bfg dr's I have for my Acura feel spongy as hell compared to the stock 215/50's. They wear out quickly, especially if you do alot of burnouts. Mine are pretty much void of any major tread and they have maybe 5k miles on them. Now, my situation is a little bit different because the bfg's are on my track only wheels. So the only real miles on them are to/from the race track. I dont do major burnouts, but I do a quick smokeup before each pass.
Now, after going through this with the 3 different styles of dr's I'll say this. If your gonna go more than once or twice to the drag strip per year get some slicks or MT et radials. The bfg's hook good, but its not like you can expect 1.7 60's without some suspension work & good driving. I sometimes struggle to pull 1.9's if the track isnt prepped well. I dont like slipping the clutch a ton either, because they arent cheap nor easy to replace. After this set of bfg's are done with I'm probably gonna go with ET radials from Mickey Tompson. They are a radial so they dont get loosey on the top end, and you dont have to spend extra money for tubes. Plus they just look a little bit nicer than the balooney ET Streets.
Any other questions?
