  • 2005 - 2009 Specific Tech
better traction, rear wheels, and ETC
  • Thread starter Thread starter homebrewer
  • Start date Start date Dec 11, 2006
H
homebrewer
59
Richmond VA
Dec 11, 2006
  • Dec 11, 2006
I've only had my 07 Gt for about a month, and I've already found the limit of my stock 235/55R17 Pirelli tires. On a cold day, in a completely stock car, punching it in first results in spinning the tires from 3k on up.
I'm interested in not only getting wider rear tires, but also bumping up to 18's in the back, for a few reasons. First, the added size in the back will help with the look (slightly old school, bigger in the rear), but also with more options as far as rim size compared to 17 inch wheels. As much as people complain about it, and as much as I check my tire pressure, for some reason I kinda like the tire pressure monitoring.... it just seems like a nice feature.
So who here has replaced their rear wheels with a different size than the front, and did it cause an issue with the TPMS? I guess that in the end I could choose a rear tire that would have the same effective outside diameter as the front tire, which would not affect the pressure system.... but I don't want to be constrained to that. I'm just looking for a wider rear tire, with good traction, that doesn't require changing all 4 wheels.
P.S... On a somewhat related note.... what is the widest rear tire that fits on the 07 GT without other mods? I'm not too concerned about backspacing as long as it fits mostly under the fender flare. This could influence my decision on what to do... I'm just ready to upgrade after dealing with these pirelli's.
H
Hoboattacker
542
Baton Rouge (LSU) / Houston, TX
Dec 12, 2006
  • Dec 12, 2006
2005 and 2006 GT's you can easily fit a 295 tire out back. I'm sure that there aren't many, if any, differences in the wheel wells between 05/06 and 07.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Dec 12, 2006
  • Dec 12, 2006
I have noticed some gain in traction from the stock 17" Pirelli's to the stock 18" BFG's. I haven't done much upper limit driving really stressing the traction limits of either tire, but day in day out there is a difference. Just remember that going to a larger wheel/wider tire more times than not means adding weight/rolling resistance which chews up useable power on an unmodified car(such as mine...for now). I will be adding CAI/tuner and 4.10s which will not only more than make up that power robbing weight difference, but also put me back to the traction limited side again. Perhaps then I will look into a possible set of drag radials for spring-fall driving.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 12, 2006
  • Dec 12, 2006
Just an aside here: Don't forget the Tire Pressure Monitoring sensors on your stock wheels will need to be transfered over to the larger diameter rims. This will require that you purchase new straps from your dealer (or online) and making sure the sensors are not discarded for the swap...
D
drsam
35
KY
Dec 12, 2006
  • Dec 12, 2006
I know what you mean!
Can't believe Ford even put that tire size on. I actually already had my replacements ordered before i got the car. I have 18 inch steeda wheels and 275/35/18 BF Goodrich tires. Tremendous difference. I did not know about getting the tire sensors out of my stock wheels and my TPM light stays on constantly so do that. There are some threads here that mention replacement straps for the sensors.
Good luck.
H
homebrewer
59
Richmond VA
Dec 12, 2006
  • Dec 12, 2006
Thanks for the replies all, but what I'm really wondering is if the TPM light will come on, even if I do switch the sensors over.
The way I understand it, the computer reads the rotational velocity of each sensor, and if one is slower than the rest, it will turn on the light. This is because a flat tire will rotate slower than an inflated tire. If I put 18's on the back, and leave the 17's in front, this would make the rear tires turn slower than the front.
In theory, I could buy front tires so that the total overall outside diameter of each tire (regardless of wheel size) is the same. But again, that is a pain, and I'd rather not have to do that.
So is there a way to program the tire pressure monitor for larger wheels in the rear than the front?
kooldawg6
Aug 31, 2006
1,679
Central VA
Dec 12, 2006
  • Dec 12, 2006
Ditch the tire pressure system and buy a $5-10 gauge and check at least once per month and put whatever size tire wheel/combo you can afford and/or fit.
D
drsam
35
KY
Dec 13, 2006
  • Dec 13, 2006
Would like to ditch TPM!
Right now i'm chosing the ignore the warning light but would love to keep it from coming on. Does anyone know how to disable this light without using a sledgehammer?
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
H
Best tire size for 91 Fox 18x9 wheels. On coilovers
  • hassler
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
KRUISR
