Bezel Painted...Sony Installed...Must See JR!
94GTLaserRC said:
Yeah, it's so hard to get good interior shots of the car...how does the curvature on the bezel look?
Hey Pune, havent seen you around in awhile..Welcome back!
Yeah, I spend about 8-10 hours a day on a computer at work, so the last thing I want to do when I come home is flip on the computer.
Thanks for the tips, I love the Roush interior also.
That's a good idea with the outer A/C Vents...just paint the rims. NOW, on that car, the WHOLE shift bezel colored looks ok, but I think on mine, with the red, it would be too much...
Thanks for the pic.
RC
94SC50 said:
Over the top of the spare cup there is a screw on each side.
Yes, see those indentations on either side in my pic...THose are Tq screws, I think they are t-20's.
You have to lift up the shift bezel (lifts right up) and remove it..Then take out the 2 tq screws..Now, when you pull out the spare cup there is a long plastic piece going back, which the stock radio rests on..That is connected way in the back by another tq screw, which I believe you access through the space vacated by the spare cup.. I just broke mine off b/c it was hard to get to :lol: (dont worry if that happens...it still goes back) Just make sure when you remove it, you take the A/C top vents WITH IT...I tried to separate them and they broke, and I had to epoxy them back on. You can separate the Mach Face, and you will see a tab on each side of the Mach behind the bezel which will allow you to remove that....You have an antena wire, power wire, and speaker harness to remove, and a ground wire...there are also 2 wires to remove on the shift bezel ligher.
Thanks again JR :nice: The Door cups will take a little longer, since they are "handled", I will put an extra coat of primer and a couple extra coats of color.
RC
