  • 1994 - 1995 Specific Tech
BIG ****ING PROBLEM, NEED HELP NOW!!!!
  • Thread starter Thread starter 1994Vib.RedGT
  • Start date Start date Jul 12, 2006
1994Vib.RedGT
585
Denver, CO
Jul 12, 2006
  • Jul 12, 2006
So Apparently I was not told by the manual that there was a coolant drain on the engine too, I was only aware of the radiator, I undid my head bolts, and coolant went everywhere, more than likely ALL down in the motor as well, what do I do??? Am I looking at a new engine?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 12, 2006
  • Jul 12, 2006
should be fine, why were you removing the head bolts? new gaskets i assume
change the oil and youll be good
1994Vib.RedGT
585
Denver, CO
Jul 12, 2006
  • Jul 12, 2006
actually Im doing a head swap, but so if I change the oil before I crank the motor I will be fine? how many times should I change the oil?
94CobraPace
907
Houston, Tx.
Jul 12, 2006
  • Jul 12, 2006
Yep, just change the oil before starting & you will be fine.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 12, 2006
  • Jul 12, 2006
Yeah drail the engine oil, clean the coolant out of the cylinders, pour new oil in once the car is back together, yank the dizzy, get a drill and attach a 1/4" socket to the end, and run the oil pump counterclockwise for a few minutes. Drain the oil and put in a new filter. Reinstall the dizzy and you are done.
You can just change the oil and drive it for a few minutes to get all of the coolant mixed with the oil, then change the oil again. But I wouldn't recommend it.
Scott
Y
yellow1995Cobra
2,959
Massachusetts
Jul 12, 2006
  • Jul 12, 2006
it happens to everyone, no biggie. Like everyone else said just change the oil.
1994Vib.RedGT
585
Denver, CO
Jul 12, 2006
  • Jul 12, 2006
aargh!!!!!!! so I go to drain the oil, and my oil pan bolts are not only rounded over, but they are on there SO damn tight that I cant get them off, with anything be it a wrench, socket, torque wrench or even channel-locks. Im going to go kill someone at the local oil change place tommorow for doing this, because of the coolant now the oil pan I got absolutely ZERO work done tonight, Im so pissed off right now.
sick_azz_cobra
122
west palm beach,fl
Jul 12, 2006
  • Jul 12, 2006
hmmm i have a suggestion......
1) place right and left thumb and pointer finger on right and left earlobes.
2) now rub earlobes while saying.....
WOOOOOOSAAAAAAAAH WOOOOOOSAAAAAAH
3) DRINK A BEER AND RELAX
I had the same problem on my drain bolt so if your skilled enough try this but be careful not to go through the oil pan..... screwdriver and hammer thats what i used and it worked get a groove started and smack it one good time then twist off by hand.
4) when you get them undone take the bolts to the oil change place and throw them at whoever changed your oil.
bill302
2,131
alabama,gadsden
Jul 12, 2006
  • Jul 12, 2006
use a small pipe wrench it will get any rounded bolt off i know believe me...then buy a new bolt at the local parts store...
Guero
2,148
Jul 12, 2006
#10
  • Jul 12, 2006
  • #10
FlyBy763
439
Palm Bay, FL
Jul 12, 2006
#11
  • Jul 12, 2006
  • #11
Vise-grips...
WhiteCobra95
641
180
74
Jul 12, 2006
#12
  • Jul 12, 2006
  • #12
Craftsman has some good sockets for removing stripped bolts. They could probably take out your drain plugs fairly easily. Just make sure you get the right size for the job! They're not that expensive either. I hope you have a Sears near by. Good luck dude!
HISSIN50
34
129
Jul 12, 2006
#13
  • Jul 12, 2006
  • #13
Excellent idea here. I recently had to do this after a family members sig. other rounded off the drain plug. Took me a solid 5 seconds to have the bolt removed - those Bolt-outs are slick.
Good luck.
H
HighMileageVert
15
#14
  • Jul 12, 2006
  • #14
3rd for the bolt outs -- Craftsman saves the day.
I kinda like my new bolts from the dealer -- integrated o-ring.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 12, 2006
#15
  • Jul 12, 2006
  • #15
You'll never have to deal with all that mess on the floor again
if
You replace the lowest level block drain plugs on each side with those t-handle screw in/out type valves.
The valves look a lot like the petcock you see on the bottom of radiators.
Next time you gotta take off the heads ...........
You'll have a way to drain the block
No Muss ... No Fuss
Grady
gcomfx.com
3,690
Republic, MO
Jul 13, 2006
#16
  • Jul 13, 2006
  • #16
When you get a new drain plug.... get a magnetic one.
mytight95
2,605
Dothan,Al
Jul 13, 2006
#17
  • Jul 13, 2006
  • #17
good tips ....both of you Grady and Paul....
jason
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
