biggest tire ?
  • Thread starter Thread starter 351w fastback
  • Start date Start date Oct 15, 2004
351w fastback
91
  • Oct 15, 2004
i have a 67 mustang with a 8.8 rearend. right now i have 15x7 with 225/70 in back. i want to get the biggest tire possible without sticking out past the fender very much. the rearend is like 2 inches narrower than the stock 8 inch was so does that help me? i was thinking about getting 15x8 in back. is it possible to get 275 back there?
thanks
SandSprite
332
L.A., CA
Oct 15, 2004
  • Oct 15, 2004
Maybe check Nick's wheel/tire database. Find the largest rubber you can fit, then play with backspacing accordingly.
http://www.dodgestang.com/mustang.htm
And what 8.8 did you use?
351w fastback
91
  • Oct 16, 2004
the chart says it can fit but i was just worried about like the bulge of the side of the tire and rubbing. the 8.8" is from a 94 explorer. 3.73's with limited slip for $175. me and my dad just shortened the longer side and got the shorter axle from another rearend. no problems so far after about 8,000 miles.
SandSprite
332
L.A., CA
Oct 16, 2004
  • Oct 16, 2004
Cool. Do you know exactly how wide it is drum to drum (or disc to disc)? I think it's quite a bit narrower than a stock 67 rear end (59.25"), so you won't need much backspacing.
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
