  • SVT Tech Forum
Bit by the Cobra
  • Thread starter Thread starter JoeWeckbacher
  • Start date Start date May 4, 2011
JoeWeckbacher
  • May 4, 2011
After owning my first cobra for a month ( my first mustang ever), I thought I bombed it when it started surging at high rpm. Luckily, I had installed an electric fuel pressure gauge that went absolutley nuts when the car started acting up....maxing out 100psi. Accompanied by a po190 code for frp sensor malfunction and some reading on the forums, I replaced the frp sensor which solved the problem. $100 at my local dealer. Apparently this is a common problem on the terminator when boost levels are modified. Is there an aftermarket cure for this pattern problem?? Any input would be great.
KJ Hoppus
1,008
Elk Grove CA
Jun 4, 2011
  • Jun 4, 2011
I dont believe there is anything we can do about it. every oil change i check mine for fuel in the lines and in the old oil.
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • SVT Tech Forum
