  • SN95 4.6L Mustang Tech
bleeding brakes
  • Thread starter Thread starter tag4car
  • Start date Start date Sep 5, 2008
tag4car
Birmingham AL
Sep 5, 2008
  • Sep 5, 2008
i've never worked on brakes before but i'd like to learn, how exactly do i go about bleeding my front brakes, i'm about to install an sllp linelock and i want to do it all on my on.
such a noob question!!
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 5, 2008
  • Sep 5, 2008
Crack bleeder scew open, have friend push brake, when brake is to floor, close bleeder screw. Repeat.
But....installing line lock may require you to bleed them with a scanner since you are breaking open the ABS unit.
snowb07
235
soon to be CT
Sep 5, 2008
  • Sep 5, 2008
do a search on here. just a few weeks ago there was a great how to for both installing the SLP line loc and then bleeding your brakes.
G
GettinThere
553
Central Texas
Sep 5, 2008
  • Sep 5, 2008
SVT32VDOHC said:
...have friend push brake...
Speedbleeders are great if you don't have someone to help you.
CobraRed_96_GT
1,421
UCSD/La Jolla
Sep 5, 2008
  • Sep 5, 2008
don't need em. Get a 20oz coke bottle. Put some brake fluid in it to fill it like 1/5 the way. Get a tube and connect it to the bleeder screw then submerge it in bottle fluid - keep pumping the brake until all the bubbles are gone - keep MC full and repeat process untill fully bled starting from furthest caliper from the MC.
T
TripleBlk
312
Cape Canaveral FL
Sep 7, 2008
  • Sep 7, 2008
One tip I gleaned from this forum on my last brake bleeding adventure ( I had to change out a front caliper), is that it REALLY helps to bleed the master cylinder as well, if the brake pedal is a bit "mushy".
It took a container of clean brake fluid, a 10mm bleeder wrench, a clear 1/4" ID plastic tube, and an assistant to hold the brake pedal down while I cracked the bleeder screw(s) open. Done in less than two minutes, and I'm slow !
HTH
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,107
224
Massachusetts
Sep 7, 2008
  • Sep 7, 2008
That's how i do it. I even managed to do it alone without speed bleeders.
Just put the line in a bottle of fluid and pump the pedal. When you lift up on the pedal, it draws fluid from the MC...not back through the bleeder.
Bleed all 4 brakes starting from rear to front. Then bleed the MC (there are two scrwws on the side)
I bleed my brakes yearly. Every time after i'm done, the pedal feels so much better with fresh fluid.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 7, 2008
  • Sep 7, 2008
at work i used a Vacula, at home i use speed bleeders. when i had the mustang i would flush the system at every oil change, about 6 months. i didnt have ABS, so it was easy.
tag4car
Birmingham AL
Sep 8, 2008
  • Sep 8, 2008
INSTALLED
first off PITA,
slp's instructions are about as readable as used toilet paper!! but it's on, talk about a tight space for real, i went out and got one of these Craftsman Vacuum Pump/Brake Bleed Kit - Model 20930 at Sears.com
and one of these Lisle Brake Bleeder - Model 19200 at Sears.com
i started in the pass rear the driver rear then pass frt then drv frt, i did do the MC 1st. the car does stop but not as firm as it did, the pedal feels soft. What now, Bleed again?
snowb07
235
soon to be CT
Sep 8, 2008
#10
  • Sep 8, 2008
  • #10
yes, bleed again. there might still be some air pockets in the line. After I installed mine I had to bleed the brakes twice as well.
joshheat25
871
Delaware
Sep 8, 2008
#11
  • Sep 8, 2008
  • #11
you don't even need anyone else to help you like said before just attach a hose to the end of the bleeder screw I believe it's 1/4 inch inside diameter and pump away into a containter
SVT32VDOHC
3,501
28
119
Motor City
Sep 10, 2008
#12
  • Sep 10, 2008
  • #12
I typed a book in the other bleeding brakes thread in this forum. My car had trouble because I swapped all the GT stuff into a fox body, so I have every line open. Nothing got the brakes perfect, til I bled the M/C. Highly recommend it. My Dad said a ton of air came out of it, when I pushed the pedal.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
