Ok,
I am wondering, have you checked out aftermarket cams for a 4.6 from more than just VT? Just curious...
I really don't like how companies classify their cams... The Comp line of Cams especially the Comp 270 PI cam work well both N/A and in a SC application. Crower Stage 2 SC PI cam is almost identical in specs compared to the Comp 270 except the Crower cam has more lift.
I am using the Crower Stg 2 SC PI cam in my N/A application and I have no intentions of ever adding a SC. According to your post, it wouldn't make any more power than if it had stock cams, well...
My car with the plastic PI intake, auto transmission and IRS is making more power( about 20 RWHP ) than a car with similar engine specs( 5.0L Big-Bore ) as mine that has VT Stg 2 N/A cams, higher compression ratio and the Fox lake P51 intake and is in a 5 Spd manual mustang. The advantages in parts that my car has, is the bigger Crower Cams and better heads, everything else the mustang has the advantage...
In short, most 4.6 S/C cams will work in a N/A application and work quite well doing so...
