Blown Transmission
I've run it without the spacer before too. Actually I don't have a spacer. I put mine in before they made that nifty spacer, and I have to have a custom driveshaft made. It's ok for a short period of time.
You can change the shifter out later. You have to lower the transmission, but it's really no big deal. Just put a jack under it, and remove the bolts at each end of the cross member, and lower it down. You just need a little extra space to get to those bolts. It doesn't take much time at all.
Kurt
Kurt
I bit the bullet and bought the freaking shifter Urgh~, I just didn't want to deal with this later, i also ordered the rear spacer,
Got the 2 shorter bolts for the top,
Got the tremec bell-housing
Got the fox fork
That's it right? i just wanted to make sure.
Do i need to change the clutch cable to fox cable or do i keep the current cable? Just wondering
Thanks
