Body Roll
xruiz
31
Houston,TX
Ok guys here's the deal, I just got my rear tires changed. I got new 275/40/17 Kumho Ectsa ASX's put on my stock rims the front tires are still the stock tires that came with my 03 stang. Now that I put these tires on I'm getting WAY too much body roll. What could I do to get rid of that? -Any help is appreciated. :)
umm much simpler than that, um now u have different tires(tread wear) from front to back which messes up alot of things, the slight change in balance of the car plus, traction differences is probably the problem
ugh.......
Look he changed from a STOCK all-weather tire to a SPORT tire. Nothing is wrong as long as you change both fronts or both rears. You can feel what your suspension is doing more with the sportier tires.
The tires are waaayyy to wide for stock 8" rims. You are likely getting a lot of sidewall flex. Look at the specs for any tire manufacturer and NONE of them recommend putting anything wider than 255 on a 17x8 inch rim.
Here is a link to the page for that tire. Click on the Specification link under the pic of the tire. Kumho recommends a 9.5" rim for that size tire.
http://www.kumhotires.com/int/Tires/PassDetail.jsp?pattern_name=KU21
So basically you guys are telling me that I need a bigger for the size tire that i'm currently running in the rear? Also, Is too much body roll a bad thing? I know it feels really bad but can it mess up anything in my car or can it be dangerous? :shrug: Sorry if these questions are dumb.
dude i say just get a sway bar and a little more upgrades to reduce body roll ...but what do i know i just had 2 kumho tires on my back 2 rims(stock) also :shrug:
