Body Squeeks
  • Thread starter Thread starter blue68pony
  • Start date Start date Sep 4, 2007
blue68pony
Washington state
Sep 4, 2007
  • Sep 4, 2007
Hi all, wife and I recently purchased a '68 Mustang. Car is very nice with the exception that the body squeeks in the front end. I have tried to isolate 'where' it's coming from and sounds mostly on driver side. Does anyone have any suggestions on how to get rid of the squeeks? Any info would be helpfull.
Thanks!!
suki243
662
Southern California
Sep 4, 2007
  • Sep 4, 2007
the body squeaks? Is it the shocks?
Jenns01TA
37
Sep 4, 2007
  • Sep 4, 2007
Nice purchase! Welcome to Stangnet.
I'm moving this to our classic section to provide you access to our members there and all their knowledge.
Good group of folks. Enjoy the Stang.
BarnStang
1,260
Hagerstown, MD
Sep 4, 2007
  • Sep 4, 2007
Either a ball joint or A arm bushing. We just had a 69 Mach1 that squeaked no matter what we tried. Found one A arm bushing worn out. THat fixed half the squeak. Nothing left but the upper ball joint. Even though it was not loose, and we greased it, still squeaked. Replaced it and no more squeak. ALso, check the spring saddles. Make sure the rubber is still intact. And as already posted, the rubber washers on the lower shock mounts can wear out and actualy fall off. That will squeak too.
Soaring1
Banned
Jan 3, 2003
144
Texas
Sep 4, 2007
  • Sep 4, 2007
If the upper and lower control arms have a grease zerk to grease the ball joints that is what you need to do. Otherwise, drill it, tap it and insert a 90 degree zerk so you can grease them.
BarnStang
1,260
Hagerstown, MD
Sep 5, 2007
  • Sep 5, 2007
THe upper A arm bushings should also have grease fittings. Make sure the bushing caps are tight if they are the screw in style. If it still squeaks after you grease everything, something is worn out and will need replaced.
blue68pony
Washington state
Sep 7, 2007
  • Sep 7, 2007
Hi all, thanks for the info on where to start looking.
Manual disc brakes
  • Butchd88
  • Feb 28, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
