I am bleeding my brakes now and I have a problem. I have done all the wheels starting with the passenger rear, then driver rear, passenger front, and I am currently on the driver front. The first three wheels went fine, all air out. Now on the driver I am encountering a problem. I cannot get the air out for the life of me. Also when I pump it fast it seems that the brake fluid is becoming agitated and has many small bubbles in it. Also from the cabin against the firewall where the master cylinder is hooked up there is a strange almost gurgling sound. It is odd that the first three went fine and this front driver side wheel is giving me the problem.
Please, any recommendations would be helpful. By the way I am using a Granada setup with a Wilwood Proportioning valve and a 74 Maverick Master Cylinder and speed bleeders on all four corners.
Is there a seal in the back of this MC that where the brake pedal push rod could have messed up? Where is this air coming from?
