Brake Bleeding
  • Thread starter Thread starter 87VERT
  • Start date Start date Jul 6, 2005
87VERT
1,275
Toronto,Ontario
Jul 6, 2005
  • Jul 6, 2005
This weekend I'm going to be changing my rotors, pads, calipers and front flex lines. This would also be a good time to flush out the old brake fluid in the rear lines. My question is should I wait until I replace the front lines and calipers before I start bleeding the rears or should I bleed the rear lines first before I open up the front lines and calipers? This is my first time bleeding a brake system so any tips or suggestions would be greatly appreciated.
Bryan
garystocker
305
New Jersey
Jul 6, 2005
  • Jul 6, 2005
It dosn't matter. Do it all at once. Then bleed in this order:
RR LR RF LF from farthest away from the master cylinder to nearest.
PuterAmI
513
Madison, Alabama
Jul 6, 2005
  • Jul 6, 2005
I have always bought two quarts to do this.
The front and rear are two completely separate systems which is why it does not matter.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jul 6, 2005
  • Jul 6, 2005
I'd swap the parts and then bleed the system all at once. But that is just me. As mentioned in the two posts above mine, start in the rear and work your way around the car when you bleed.
slow93
406
  • Jul 6, 2005
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
