Been there & done that…
Fox instructions for stock booster:
1.) Remove the 2 nuts holding the master cylinder to the booster. Pull back on the master cylinder until it clears the booster.. This works in some cases but not every time. If there is not sufficient clearance to remove the booster, you will have to bolt the master cylinder back down so that you can remove the brake lines.
2.) Open the driver’s door & slide the seat all the way back.
3.) Sit down on the ground between the open door and the door sill.
4.) Use a 3/8” ratchet, 12” extension, 3/8” universal adapter, and a ½” socket. If you have access to a ½” Snap On semi deep universal socket, that is even better. The studs stick out enough that a deeper socket works better.
5.) Remove all 4 nuts and save them. The booster may have metric nuts and replacing them can be tricky.
6.) Wiggle the booster out and up to get it past the master cylinder.
7.) Note the push rod and its adjustment. The new booster may require some adjusting. Too much adjustment and the brakes drag. Too little adjustment and the pedal hits the floor before you develop full braking power.
8.) Reassemble in reverse order, be prepared to bleed the brakes if you had to disconnect the master cylinder brake lines.
