like posted above i set of cross drilled and or slotted rotors would help. plus a set of pads that are for open track use. ones that work best in really hot conditions.
the down side with the pads that work in hot condition is that they suck when they are cool. like when your driving in the street. when i first bought my cobra the car already have the red pads from EBC ( i think that the name of the company) and i was wondering why the car was horrible at braking. so i go for a brake change and find out that the red ones are for track use, and they didn't work good for the street cause of the compound make of the pad.
i ended up changing them out for the green ones (street pads), and they suck as well. but a brake pad thats is made up for the track is your ticket. the problem is they won't get the job done on the street for your DD.
another thing, from my understanding (i'm not 100%) you can't cut slotted, crossed drilled, or rotors that are both slotted and cross drilled on a lathe. maybe someone else can clear that one up.
your best bet might be to have a rotor, and brake pad setup for the track, and switch them out for the track days.
