brake fitting straightening
  • Thread starter Thread starter 50gt1988
  • Start date Start date Apr 2, 2005
50gt1988
154
Spanaway, WA
Apr 2, 2005
  • Apr 2, 2005
Ok, I'm doing a rear disc brake conversion on my car and I got the MC conversion T from Matt at www.svo73mm.cjb.net but when it screws into the prop. valve the side brake port opening faces the fender wall when its tightened. How do I get it to tighten to were its facing the rear of the car were it's supposed to face?
50gt1988
154
Spanaway, WA
Apr 2, 2005
  • Apr 2, 2005
Ttt
50gt1988
154
Spanaway, WA
Apr 2, 2005
  • Apr 2, 2005
anyone??
50gt1988
154
Spanaway, WA
Apr 2, 2005
  • Apr 2, 2005
t
ALMOST STOCK
1,250
41
88
CA.
Apr 2, 2005
  • Apr 2, 2005
50gt1988 said:
anyone??
I think this will help answer your ?
http://www.corral.net/forums/showthread.php?t=620021&highlight=weatherhead
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 2, 2005
  • Apr 2, 2005
Maximum Motorsports makes a kit too and you can adjust it to point whichever direction you want it to.
Asha'man
1,909
Denver
Apr 3, 2005
  • Apr 3, 2005
Hit up your local Napa stores and find a Weatherhead 7914 that threads correctly with your specific proportioning valve. I pulled a PV from the junkyard to use to make sure all my fittings fit correctly, and then just used that PV in the swap.
Brian
R
ratrapp
510
buena vista,va
Apr 3, 2005
  • Apr 3, 2005
asha'man's right.i had to do the same thing when i got my 3-2 port kit from matt also.
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
