brake fitting straightening
50gt1988
154
Spanaway, WA
Ok, I'm doing a rear disc brake conversion on my car and I got the MC conversion T from Matt at www.svo73mm.cjb.net but when it screws into the prop. valve the side brake port opening faces the fender wall when its tightened. How do I get it to tighten to were its facing the rear of the car were it's supposed to face?
Hit up your local Napa stores and find a Weatherhead 7914 that threads correctly with your specific proportioning valve. I pulled a PV from the junkyard to use to make sure all my fittings fit correctly, and then just used that PV in the swap.
Brian
