Brake light comes on when I shift??? help
  • Thread starter Thread starter IMPORTSMOKER
  • Start date Start date Apr 20, 2004
IMPORTSMOKER
201
RIVERSIDE, CA
Apr 20, 2004
  • Apr 20, 2004
Lately I have been noticing that when I shift in to 2nd and 3rd, my e-brake dash light comes on! What the hech is that? its bugging me...It is getting more frequent in 2nd and comes on in 3rd when I shift a little higher rpm...it flashes on briefly right when I shift and then let out the clutch...any assistance would be greatly appriciated..thanks
HISSIN50
34
129
Apr 20, 2004
  • Apr 20, 2004
how is the brake fluid level (the light normally is for not only letting you know the ebrake is applied, but also letting you know you have low fluid). i cant remember off the top of my head if the stang has a low level sender, but i would bet it does. i have some older stuff that does not, and i forget what is what.
top up the fluid and you might fix it. when you shift, you slosh the fluid around, and it might allow the float (sender mechanism) to sink (while fluid sloshes) and illuminate the light for a second.
good luck.
UMDSmith
226
Salisbury, Maryland
Apr 20, 2004
  • Apr 20, 2004
mine does as well.
Does it come off if you tap your brake??
My friend said on his thunderbird that used to happen because he needed a brake job, since his reare drums were very worn. In my case that would work, because my brakes are close to being completely done.
I think it has something to do with worn down brakes and having the back sensor tripped.
BlueThunder1988
102
  • Apr 20, 2004
Another vote for brake fluid level... been there!
HISSIN50
34
129
Apr 20, 2004
  • Apr 20, 2004
UMDSmith said:
mine does as well.
Huh????????
as far as i know, there are no wear sensors on the brakes at all. about the only sensor you will find in the vicinity is an ABS speed sensor....if so equipped.
im guessing that you must be thinking of your new Mercedes or something.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,117
224
Massachusetts
Apr 20, 2004
  • Apr 20, 2004
UMDSmith said:
mine does as well.
There are no sensors on the brakes.
WHat happens is when your brakes wear way down, the pistons and wheel cylinders are pushed out far because there is little pad. This draws brake fluid out of the MC resevior and trips the low fluid light.
The BRAKE light in Mustangs shows you when the E-brake is up, OR you are low on fluid. Those are the only reasons it should come on.
Stump1000
495
Morristown Tn
Apr 20, 2004
  • Apr 20, 2004
i say fluid level
IMPORTSMOKER
201
RIVERSIDE, CA
Apr 20, 2004
  • Apr 20, 2004
Thanks guys, I checked the fluid...it was low.....filled it up and no more brake light...What would I do without Stangnet???
5.0guy
320
MI
Apr 21, 2004
  • Apr 21, 2004
check your brakes now..
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
