brake light on/off
  • Thread starter Thread starter 95_gts
  • Start date Start date Jan 9, 2008
9
95_gts
  • Jan 9, 2008
hey guys my parking brake warning light has been going on and off for probably about a year...i havent noticed any consistency to its appearance or disappearance...im thinking it needs some master cylinder fluid added? can i just do this myself or should i get it checked out?
thanks!
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Jan 9, 2008
  • Jan 9, 2008
The parking brake is enganged by a lever and cable. I dont think the fluid has anything to do with it. However, mine has been on now for a month and I havent bothered to look at it yet. I think the length and tension can be adjusted where it hooks up to the rear calipers. Maybe I'll look at mine and let ya know what I find out.
95strokerPSU
986
Sacramento from Philly
Jan 9, 2008
  • Jan 9, 2008
Low brake fluid level will trigger the brake light. Check your fluid level
9
95_gts
  • Jan 9, 2008
im pretty naive with this kind of stuff ...how do i check my fluid level?
BlackVert
5,589
9
98
Bethesda, MD
Jan 9, 2008
  • Jan 9, 2008
i have my console out right now. the parking brake light is triggered by a little spring mounted screw mounted at the base of the parking brake. it looks like it is adjustable. you have to take the console out to get to it though, that takes about 15 minutes. i bet you could get it done in an hour.
HISSIN50
34
129
Jan 9, 2008
  • Jan 9, 2008
The guys are right. The E-brake and fluid sensor can both cause the light. If the system is not leaking and was topped up after a pad swap, but now the light is on, consider the pads being about finished (as they wear, the fluid level drops).
Sometimes a hill, acceleration, braking, etc can cause the fluid to slosh and the light to come on briefly. On some cars I've seen the floats for the sensor get wonky (I cant remember if we use a float or a fixed level switch).
Good luck.
95BlueStallion
5,130
3,103
214
Cedar Rapids, Iowa
Jan 10, 2008
  • Jan 10, 2008
Damn hissin youre full of all sorts of useful information! My light breifly turns off when I leave a light, but then comes back on solid. I bet my fluid is low cause my rear pads are shot. New pads are going on, so that problem should fix itself.
9
95_gts
  • Jan 10, 2008
appreciate all the help fellas!
SN95StangMan
1,292
Lynwood, CA
Jan 11, 2008
  • Jan 11, 2008
HISSIN50 said:
wonky
Good luck.
We use a float
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
