Brake problems
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
So i was out friday night cruzin in town and i parked my car. a couple mins lata my friend got in it to drive it and he said the brakes wouldnt work until all the way to the floor but the fronts wouldnt work and the back ones would lock up. i pused the car back and all kinds of fluid was on the pavement. one line was loose and i tightened it back up. my brake light is on now. Do u think they just need to bleed??
I think you need to find out why a line came loose and make sure there is not a problem there first. You will obviously then need to bleed your brakes and top off your reservoir with fresh fluid. Good Luck.
Yeah inspect both brake lines and make sure they are in good shape then bleed the brakes. Also, check your proportioning valve, as they go bad on the olds FOX body mustangs. I sell those a lot at my work.
Yup, the light is merely a low fluid indicator. Air was let into the system, so I would bleed the system and then try to diagnose what is going on. Where did the line come undone? at the PV, MC, Caliper, inner fenderwell?
well i had the problem fixed. i took the brakes completely off and put the back on and bleed the brakes. they worked fine but no its doing the same thing again. but i found whats causing the problem. i recently lower the car 2" and is causing the steel line from the calliper to hit the steel line on the fender well when i turn right. the line on the calliper comes loose. im goin to look at it some more. is thier anyway to relocate the line to the fenderwell higher so they wont hit?? This is on the passenger side. thanks for help!
